Today I reassembled the canopy frame and bubble to fit the canopy side skirts. I layed out the rivet locations on the stock sheet of aluminium and drilled the holes. Then I fitted it to the Wd-725 canopy side rail and match drilled the side rail. Then I back drilled the Wd-725 canopy side rail throught the canopy bubble retaining screw holes into the C-603 canopy side skirt. Finally everything was disassembled, edge finished, deburred, dimpled and countersunk as required.
Canopy frame and bubble reassembled for the side skirt installation
